[QUOTE = "JKD, post: 38897, member: 111"] Rear viewfinder
Developing a small utility to experiment with the messages exchanged between the different Hyundai software modules, I found the possibility of activating the rear camera without the need to turn back :
So I have put hands to work to offer you this feature. The application that I programmed allows you to activate the rear camera while driving forward. On the right side, a small button will appear to close the viewer. If you turn the reverse gear and then remove it, the program will close automatically. If you press the close button, the viewfinder will close even if you have the reverse gear set, but that does not affect the parking sensors that will remain active as long as you do not change gears. Note that the parking sensors only activate when the reverse gear is engaged. My application does not activate or deactivate them. It only shows the viewer.
However. Not everything is so beautiful. I have checked that if you exceed 44 km / h the screen stays black . That is, the image is lost and does not recover until it descends below 30 km / h . This may be a safety limitation so as not to get distracted at high speeds. I do not know at the moment if this limitation is given by the software of the equipment ( BART.exe ) or if the limitation comes from outside. But for now it's just another curiosity that you can download.
[/ QUOTE]
hi
thank you veru much for nice invaluable application.
Unfortunately I can not download it from Google Drive.
Please download the download link.
best wishes.
[MEDIA = youtube] NqAzpIsZtWM [/ MEDIA]
[ATTACH = full] 3456 [/ ATTACH]
downloads
[/ QUOTE]
hi
best wishes.
