Menavrus de Menaco
gracias por su consejo. Entonces, ¿no hay manera de iniciar automáticamente al menos?
Hi,
You must create a button for tucsy on main menu in the same way as other buttons in menavrus.cfg and insert this line in the button's section you want to autorun:
AutoExec = 1
Thanks to JKD
Reacciones: Dan
¿Alguien mejoró a 20.178? ¿cuál es el procedimiento?
Solo lea el tema completo, no muy claro para mí si alguien hizo la actualización e instaló Menavrus.
Tengo este boletín de los desarrolladores de Menavrus:
No, Menaco does not support it.
Ver. 20.178 is not the official version yet and has a few problems on some Headunits. Perhaps it is a betta version.
But in the Internet you can find informal recommendations of users how to have Menaco with 20.178.
Ok. De nada!
It can be installed manually (I have already done it), but it is at your own risk, as you can brick your unit if something goes wrong.
You should rename original Lisa.exe in \MMCMemory\Storage card\SYSTEM to Lisa_Native.exe and copy there Lisa.exe from menavrus installer (Menavrus-install2\LG5020-V1\rootfs\MMCMemory\storage card\SYSTEM). Then you have to copy your configuration folder in the usual location. But be aware, if something goes wrong you can kill your medianav...
Hi,
60 skins for addon: 24 -3D, 36 - 2D.
60 clocks: 12 analog, 48 digital.
All United by the "skinshanger", made using the SystemInformation program. In folders CLOCKSELECT and SKINSELECT has files CLOCKSELECT32.exe and SKINSELECT32.exe, respectively, allowing you to run the program on your computer and see how it will look on BROWSER.
When you select a skin at the same time changing the clock. Clock can be selected later.
When changing the skin, BROWSER rebooted (using a program RESET from this forum). When you change the clock there-you need to leave by clicking "House".
Change skins based on scripts (MortScript program).
Scripts perform the simplest operations: read-write files from a folder to a folder. All actions with files occur on the SD card. No actions with the internal memory of BROWSER.
Tested work on 166 and 178 firmware.
Video for KIA.
Everything is adapted for the Hyundai Tucson
Download archive.
TUCSON.rar — Yandex.Disk
Unpack. There will be many folders. Folders with "standard" addon programs - empty, serve only to understand the "structure".
In the folders PLAYER and PLAYER2, there are media players with "branded" colors of the car brand.
PLAYER - standard CorePlayer add-on. PLAYER2 - adapted by Devero voPlayer (TUCSONPLAYER), more omnivorous video compared to the standard, but also more glitchy.
LGENAVIRUN - program from this Forum (by JKD)
PARKINGMODE Forum - program from this Forum (by JKD)
WATCH - analog clocks
CLOCK - digital clocks (the folder is used for recording the analogue clock).
ARCHIBALD is a toy.
All folders are copied to the SD card, confirming the "replacement" if necessary.
Enough 16GB card. I use 32GB
Use.
All labels (except the clock) is buttons.
REG TPEG - ClockSelect or Player2 depending on the skin.
NAVIGATION & Software - Skinshanger
Icons in the upper right corner - Clock, Hard button - INFO.
km/h - ARCHIBALD or ZKBrowser, depending on the skin.
HUYNDAI - Player2, Tucson - Opera.
The exit from the analogue clock - a single tap on the screen. The exit of electronic clock - double tap on the screen.
Godspeed.
alguien puede ayudarme?
Actualicé a sw 178 y ahora ya no funciona, pero si lo reinstalo, ¿crees que funciona?
alguien puede hacer un video sobre el procedimiento manual
Para seguir usando _Menavrus con la última actualización (20.178) es necesario un pequeño pero gran programa llamado BOOTLOADER. Éste consigue que se pueda instalar cualquier aplicación, en este caso Menavrus.
¿Puede proporcionarnos paso por paso para instalar Menaco en 178?
Me gustaria conocer BOOTLOADER, me puedes indicar en que consiste , para ver sus especificaciones, por mp,? Gracias
descargado pero pagado?
tienes que pagar por la licencia?
Por supuesto!
tienes un mp.
Esto de utilizar los MP para compartir información que puede ser útil a otros compañeros no me parece correcto. ¿O es que hay alguna norma del foro que se me escapa?
Que conste que yo no tengo Menavrus.
Se te escapa
Realmente lo es. Pero hay que saber leer entre líneas.
