shorty1483
Hello everyone, @JKD @supergoofy!
I have the problem that when I play Music from Spotify or Amazon Music, the shown music art (album cover) in Tucsy is from the song before and not the actual one playing. Has anyone experienced the same or has a solution for this? Except from that, Tucsy is awesome!! I am running 20.183 firmware currently, latest Tucsy and a Samsung Galaxy S20+.
Thanks and regards!
fenixr
Kosmo
Thanks and regards!
Hi Shorty i had the same answer time ago in this post and didnt got a reply, for my experience when you change the song manually always was taking the wrong cover using the song before cover, what i noticed is that in the last version of tucsy from December, you can link your spotify account (if you are premium) to tucsy and now for me takes 5-10 seconds to update the new song cover but works fine!
shorty1483
Thanks for your answer! Your hint with linking my Spotify account in the Tucsy app is a good one, which I also figured out in meantime. The covers change in a tolerable time :D Sadly I cannot connect to my Spotify Premium with the Outstore App, or did you? When trying to activate the connection between Tucsy and Spotify with the Outstore App, Spotify throws out an invalid app ID error. I guess it checks somehow if it's an official Google Play published app...butif I have to choose, I take the solution withthe correct covers, because I hear more music than I call people in the car :p
hectormaagu
buenas, como consigo el instalador (para el pen) de tucsy? en la web no puedo. Gracias
shorty1483
[QUOTE = "hectormaagu, post: 110187, member: 9840"]
gut, wie bekomme ich den Installer (für den Stift) von tucsy? Ich kann nicht im Web. Danke dir
[/ QUOTE]
fenixr
Kosmo
Shorty in my case when in Tucsy auto app i mark " link the Spotify account " I got a "authenticated " message. what do you mean with the outstore app?
i have tucsy and oficial spotify app in my cell phone
shorty1483
The app is
1. in Google Play, but without Phone function (due to Googles tightening of permission guidelines for apps) -> Instore App
2. in the Mega link above, with Phone and Message function -> Outstore App
I am no dev, but since the Outstore App is not identified by Google Play, it seems Spotify does not accept the request to use the user data.
When I install Tucsy from Google Play, instead of the apk with phone function, linking Spotify works for me too.
So we need to have the choice atm. Tucsy with Phone function, but no Spotify link, or otherwise.
Rikitran
Hola he instalado tucsy correctamente, pero no me funciona el táctil, alguien puede ayudarme, gracias
albergino
1.6 CRDi 136 CV
Hola quería información sobre tucsy ya que mi tucson es del 18 y el navegador es muy raspado, gracias a todos
Hola he instalado tucsy en el coche y conecta bien, lo único q no me funciona el táctil, hay alguna cosa que pueda hacer, gracias, saludos
Si, en la app di permosos
¿Qué versión de Android tiene tu móvil? La versión mínima ha de ser 7.1. también debes tener instalado en el móvil "Smartwatch Wear OS"
nosotros4
Hola, tengo Tucsy con la actualización de diciembre funcionando perfectamente, ¿si actualizo el firmware a la última versión (creo que es la .140) puedo volver a instalarlo?¿funcionaría bien?, es que creo haber leído anteriormente que había algún problema.
nosotros4
Para que funcione el auto instalador, es imprescindible que funcione BootLoader. Y sí, tengo novedades al respecto. He conseguido hoy mismo ejecutarlo. Tengo que pulirlo pero para esta versión de software podremos seguir disfrutando de aplicaciones adicionales :thumbsup:
Paciencia
Hola JKD, lo primero pedir disculpas porque releyendo el hilo se ha respondido mi anterior pregunta. No obstante la ignorancia me hace dudar, en mi caso es para un Kia que lleva la versión 10.178 y veo que el BootLoader funciona con versiones como la 20.178, no se que representa ese 10 o ese 20, ¿puedo actualizar a 10.194 e instalar el BootLoader sin problema?. Muchas gracias.
178 o 194 son realmente la versión de software de tu equipo. 20. o 10. hacen referencia a la versión de tu hardware. Eso significa que a pesar de que el software a nivel global ofrezca prestaciones parecidas en la mayoría de vehículos, estos funcionan sobre plataformas diferentes.
Desconozco las diferencias de hardware que pueden existir entre la 20.xxx y la 10.xxx. me consta que en Australia algunos Tucson con Windows CE corren una versión 10.xxx y sus equipos carecían de conectividad WiFi. Pero ese no creo que fuera tu caso ya que de ser así Tucsy no tendría mucha funcionalidad sin conexión. Me consta que el software de Hyundai/Kia trata de adaptar su funcionamiento con independencia del hardware. Por ejemplo, comprueba si hay wifi, si hay mapas válidos, si dispone de servicios TomTom, si existe lector de CD, detecta el modelo del equipo y la compañía a la que va destinado el equipo para configurar que pantallas mostrar (como la información integrada del climatizador que se proporciona en algunos Kia Sportage y que los Tucson la tienen en el propio climatizador). Con esto digo que el software trata de amoldarse a diferentes equipos. Cuando cambia la versión del hardware, es que las diferencias son demasiado notables como para tenerlas en cuenta, complicando la estructura del software.
Ahora bien. En el caso que nos ocupa, si has instalado Tucsy con anterioridad y no has tenido problemas, no deberías tenerlos ahora tampoco. BootLoader no se instala. BootLoader se autoejecuta. Y se ha adaptado para funcionar en la versión de software 194. Por lo que, si descargas la última versión debería funcionar en tu equipo.
nosotros4
¡Muchísimas gracias!, grande el trabajo que realizas para todos nosotros, en cuanto tenga tiempo busco las actualizaciones y descargo tu BootLoader. Por cierto, ¿vais a seguir tu y/o Alessandro desarrollando la nueva versión de Tucsy?, es una app maravillosa, el mapa va muy bien, solo le falta el sonido y poder verlo a pantalla completa, no obstante insisto, enhorabuena por lo trabajado hasta ahora.
No me consta que Alessandro haya dejado el desarrollo de Tucsy. Yo sigo desarrollando BootLoader y otras apps pero ya no tengo tanto tiempo libre como antes como para sacar algo "bueno" o "funcional" a corto plazo. A Alessandro le pasará lo mismo :)
nosotros4
Por si alguien te pregunta, actualizado el Sorento a al versión 10.194, instalado Tucsy con tu BootLoader y funciona bien, como antes.
Reacciones: JKD
hectormaagu
Buenas, he instalado el Tucsy y me funciona perfectamente, lo único que no consigo es conectar el mirroring del teléfono, ¿podrian ayudarme? ¿cuál puede ser el problema? (Gen2x)
hectormaagu
